Urgent Shake Question
i am doing a logo animation design which the frame is 900.
also i brought a footage .mov source which i want to use for background ,but it's just 100 frame,
so i just simply drag it to 900 frame in curve editor tab .
but when i test to play my logo animation,which is frame 900 ,the source .mov just play to 100 frame and 800frames just likes still images and not move.
could someone tell me if it's correct to just drag it until 900 frame.
and why ???? after 100 frame it doesn't move and just still image....
please .......
I've never had to do it but it was a little weird.
Parameters of your quicktime filein..
In the timing tab, click retiming, set it to remap, then drag the curve to 900 frames. Make sure to change your outpoint above to 900 as well -- other wise your out will be the original 100 and you'll get 800 frames of black.
That seemed to work for me.
j
QUOTE(jimmyt @ 07/31/06, 08:26 AM) [snapback]243885[/snapback]
j
thanks anyway... i will try it later....
