Can any one help me. I am terribly stuck. I have looked through all of the material I can find on creating an animated texture, but to no avail. I purchased at texture from buycreative.com and downloaded the file. Then went through the process to place a 2d texture ---> file1 ----> lambert2. It will show up fine once I load the image into the file attributes. However once I click Use Image Sequence I will get this error in the output editor
select -r file1 ;
AEassignTextureCB file1.fileTextureName "/Users/christy/Desktop/natatorium/pooltexture/A22B_000.jpg" "Best Guess";
// Result: 1 //
// Warning: Texture file /Users/christy/Desktop/natatorium/pooltexture/A22B_000.jpg doesn't exist, node file1 //
The texure sample will go from looking like the texture to a black box. Do I need to rename my files something else? I tried filename.ext.### I tried bringing the files into photoshop and resaving them, I tried other files that weren't downloaded and have worked fine as textures in other projects.
Can anyone help?? Thanks
