Use Mel To Control Hardware Resolution
Hi all,
I wonder if it's possible to control a material node's texture resolution(Hardware Texture) with mel. I tried to use "setAttr", but failed. Seems i have to use mouse to active it.
Anybody can help?Thanks!
setAttr on the resolution atribute should do it. Make sure that the file texture actually has a resolution attribute (it wont if it's set to default resolution, so you will have to check the attribute is there, create it if needed, then set it).
