useBackground Shader in maya 6
Hi People,
As you would have noticed, maya’s useBackground shader is now renderable with Mental Ray for Maya. The problem though is that I can’t get a final gathered shadow to appear, but only and direct shadow from a light source.
Anyone know of a workaround?
B
Apply a white shader to everything then apply the render in composite with a darken mode. The use Background shader only works with Depth map shadows
But if you apply just a white shader such as a lambert , you’ll be getting variations in colour away from the shadow that you want. The white shader needs to be a surface shader of sorts that is still able to capture final gathered shadows.
Any ideas?
B
Then give it a slight ambient instead of diffuse…I can’t say that I have fullky tested this..
