Hello!
For multiple buffers rendering purpose with Mental ray I use the user frames buffers. I both use Mental Ray for Maya and mental ray standalone.
In Mental ray standalone if I have to specify all buffers I want to use by appending some lines like this:
frame buffer 2 "+rgba_16"
frame buffer 3 "+rgba_16"
In Maya I can tick in "Render Global Settings" to set which "user frame buffer" I want to use. But unfortunately I can't find where to specify what king of buffer I want (RGB, RGBA, RGBA_16...). and I need my buffers to be RGBA_16 but they remain RGBA!!
If I specify a mentalrayTextOptions with the correct lines (see above), it doesn't make any differences, I think Maya simply bypasses this text when it uses Mentalray built-in.
Any idea about using user frame buffer on 16bits per channel instead of 8?
Thanks
