QUOTE(afair @ 03/21/07, 08:03 PM) [snapback]262693[/snapback]
I've used variables for paths in fileIn's and fileOut's.
If l have a variable "shotName" that l want to use in a fileout quicktime movie this would be the syntax for the path.
"/Volumes/Drive/project/quicktime/" + shotName + ".mov"
Here's an example for a fileIn with multiple variables including the frame range.
"/Volumes/project/shots/" + Shot_name.Shot_Name + "/3d/renders/renderman/" + Shot_name.Renderman_tk + "/img/UV." + Shot_name.First_Frame + "-" + Shot_name.Last_Frame + "#.exr"
Make sure you include the quotation marks.
Cheers, Alan.
Thanks for your help. I just realized my problem was that I was expecting the fileout node to return the string in the path field but what it does is return the variable. So I thought it didn't recognize it as a variable as was just returning text (ie, it just says "shotName". But when you render, it works.
