Hey everyone, I have a pny verto ti 4600 video card, and I was wondering if I can have a monitor hooked up to it's analog output nad a tv hooked up to it;s s-video output. Basically I wanna work on the my computer monitor, and view animations on the tv.....I would just try it but my tv is a 27 inch and not very easy to get into my computer room. Thanks for any responses.
ahhhh.....get a little exorsize....it will do you some good...
Thanks for the helth tip, but how about gettin this thing to work. I have it setup, but I want the tv to just be a viewing monitor instead of a work space. Like in premiere, I want the clips to open up on the TV. Do you know of anyway to do this.....
Hey,
I tired to look this up for you but found nothing definative.
It will work one of several ways:
A. The TV out is the same oas the main monitor but converted to NTSC.
B. The TV out is a second desktop so anything you put on that desktop is seen.
C. Using the hardware codec anything in that codec plays on the TV out.
If you go into your monitors contorl panel here should be two monitors displayed the second one is probably the TV out.
With Premiere if you are using a Realtime video card that has a codec like mpeg then anything that is in the codec will be seen playing back in realtime on that card. It don't think your card is designed to do that.
Another option is to buy a cheap scan covertor so that anything on you computer screen is cloned to a NTSC display as well.
Hmmm, thanks for the suggestions. I will try to get something working, I should probably just buy a miro card or something similar.....Thanks again.
