Do you mean you applied a edit polys->texture->uv projection? Don't do that, the node will hang around like a 3d texture projection, and your cloth will slide through it.
If the built in UV's maya cloth creates for your aren't suitable, duplicate your cloth object without history, apply UVs on that, then transfer them back onto your animating cloth with polygon->transfer, and choose UVs from the option box.
