Has anybody seen a plug-in to get the UVs be saved out as an Adobe Illustrator File?
I was thinking that maybe a script could be run to generate the UVs as an mesh object in the 3d viewport and then rendered out using the Maya Vector Render Settings which has an Adobe Illustrator Image Format option in Maya 7.
But you can't do a UV Snapshot by default.
Anybody know of a solution?
Thanks
