Uv Textures Won
Oh no ,I thought i do not need any Help nomore
you all helped me so great till yet and I did get very used to maya
but now I got a problem again where I can t find a solution
or see what could be wrong
Ok ,lets start I made a model (paintball gun ion)
then i did UV texture it like everytime:
select the poly
do planermapping ,on y-coordiantes
UV-snapshot it
did cut and size a picture ,lay it over the snapshot in Photoshop,
back in maya6 do a lambert material asign it to the modelpart poly ,
did choose clolor file - load the picture I made in
So the problem now is the texture did not cover the poly one part of the model(modelpart the grip)
is black , only the upper part of the model, i can see the picture but also streched a bit???
also the same problem on other model(parts),
but I did UV texture like this a 1000 times and it was always right and lookin good.
When I take a look in the UV-Editor my picture lays over the model ,
fits right , and no black , no streches at all ,like it should be
But on the model not ,
the upper part is with texture and down is only black???
I m totaly confused,
why it showing it in the UV editor right, but do texture the model wrong
and not like in the Editor?
What I all did try out is:
I did UV map it again ,choosed again UV planner
did a new snapshot ,with pic on
I did try to UV texture it with atomatic mapping ,
normally now should change the out look of the texture of the model
cos its made for planner not atomatic ,
but it does not change at all ,the same result (up texture down black)?
only when i choose nodel which is full covered with texture it also on the model
no black parts , but why does it texture it not right with the right snapshot,
where the UV-Editor shows me I did texture it right
it show there that the picture is layin over the model in the left upper corner where
the model is fit right into, but on the model it is wrong textured not like in the UV-Editor?
I do now what i can do now.
If sum1 got a guess what could be wrong please tell me , thanks to everyone for Help
...and sorry for my english ,I m from germany and try my best
This once happened to me as well.You can try and fix it by deleting the history or by exporting it to OBJ and then importing back. The OBJ method fixed my problems
Yea , it did function to export/import it as .OBJ
the texture now is in normal size on the model(part)
again like it should be...........
1.
"the problem was mention here is solved, sry thx ,Edit it away"
2.
and another Question what you think can cause that
maya UV problem I had and what can I do
that it might not happen again?
No idea...maya probably failed to initialize something...It only happened to me once over a significant time period so i guess its not that common, and easy to fix anyways
