Variation In Cached Data
Hi,
I have some animated curves as fluid emitters, as the animation is long and the sampling rate I need is 4, Im using this expression to create segmented cache files.
doFluidsDiskCache 2 { "mcfp", 3, 1, 0, 480, 4, 1, 1, 1, 1, 1, 1, 1, 1, "simCurves2301.mb", 50 } ;
All works perfect, but every 50 frames there is a variation in the cached data
The hole simulation look's well, but every 50 frames apears one frame without the 4
sampling Rate, it happen just in the frame in wich the new cache file is created,
please I'll apreciate if you have any idea on how to solve this problem,
ps. Maybe there is a mel or a parameter to fix the bad sampling in every first frame of cached data.
