Hey guys,
does anybody know how you can change the number of digits nuke uses for its version padding that eg. 'save new version' and toggle between versions with alt+arrowup/alt+arrow down are using? nuke seems to take whatever it can find in the name of the script or the file-in that has a leading "v" and increases or respectively decreases the number behind the v (eg. v01 becomes v02).
However, if you are using a 3 digit version padding like. 'v003', saving as a new version or especially toggeling between versions in a reader node will always break the 3 digit padding and nuke internally reduces it to two digits, so 'v003' toogled down one version shows 'v02' in the reader - and when you are working in a facility that uses a 3 digit version padding you will have a broken file-in path in the reader.
I briefly had a look at the menu.py file, but couldnt find anything that indicates or specifies the number of digits used for versioning, does anybody out there have a clue or have a similar issue? Would be so handy to be able to use the version-toggeling...
Cheers, michael.
