Hi, I have colored in my vertices of my model with the Paint Vertex Color Tool and I was wondering if there is any way to retrieve the color information of a vertex. I looked at the attributes of the vertex but there seems to be no color attribute. I'd like the color information so I can edit it with some MEL later.
Thanks for any help!
the same command used to set the vertex colours can also be used to query them:
polyColorPerVertex -query -rgb;
check out the doc for this command. Also, there are colour attributes on the mesh nodes (have a look at the mesh node doc) but weirdly they always seem to be set as 0 no matter what the colour..?
:nathaN
polyColorPerVertex -query -rgb; returns 0 0 0 if there is no color set yet.
As soon as you asign a color to a vertex it will return this color.
I mean I'm not really into vertexcolors that much but I just made myself a custom vertexColorTool to get and set vColors. Its simple but helped me a lot better than every other native maya tool yet. Whould like someone? ;]
But Naughty? How can one retrieve that mesh node color attributes? I tried to rtfm but i didn't dig it.
And do you know a way to query IF there is a color already set to a vertex or not? I mean there must be a difference somewhere..
I have the feeling that they let the vertex color stuff rot the last releases.. For instance if you vertex color and then try to undo!! -> aaahhgrrgrgrr!!! And I felt the built in Apply Poly Color tool crahed my Maya constantly .. fortunately my tool seems not to do this :]
you can get/set the attrs like so:
getAttr pCube1.colorPerVertex.vertexColor[0].vertexColorRGB;
where the [0] is the vertex index in question. If you look at the mesh node doc it shows this attr heirarchy and also mentions for the vertexColor part of the attr: The attribute is a multi with the index of the multi identifying the vertex that the color applies to so you know it should be entered with the index syntax [n]
but, as I said, it always returns 0 even if you have a colour there...? very odd... although there is another, separate vertex face attr which may yield more results but to be honest I just can't be bothered to investigate it further... ![]()
see also these old posts ewerybody:
http://www.highend3d.com/boards/index.php?showtopic=195237
http://www.highend3d.com/boards/index.php?showtopic=213248
and you're right, vertex colouring does seem to be a stagnant cess-pool..
:nathaN
hehe ![]()
didn't someone tell me they just did some vcolor stuff in the latest release.? bollocks.
jep the posts are interesting but disappointing after all
QUOTE(naughty)
hey no problem man! Already told me a lot :] Thanks!!
Hey! Thanks for the help guys! I got it working now. I was making a tool to adjust all the vertex colours in a mesh for bright/contrast hue/sat. I'm getting there!
Oh, since I am here, does anyone know if there is a scriptJob event for when the user changed the color set? I tried all the ones I thought would be it but none work! Its driving me crazy so I sort of gave up and made a button to update color values instead! I'd like to make it a bit more user friendly though...
Cheers!
