QUOTE(mikebart @ 04/01/09, 03:37 PM) [snapback]304587[/snapback]
so i guess look into that, seems like such a simple thing, im suprised its not something native to older versions of maya.
Theres a infinite number of possibilities out there, with a infinite number of variations. I am not aware thet theres a new tool in 2008 that would do this. Its just not practical to do everything thats what you have scripting for. Really you would have learned all you need on scripting between theese postings if youd REALLY wanted to. Scipting dont get much more straight forward than this. (making this a node on the otherhand is real work, id say 1 day for code, testing and deployment unles on uses python in wich case more like 20 minutes)
but here you go, im not sure what you consider the center so i modularized it.
global proc jooProjectNormalOutForm(vector $center,string $points[]){
for ($item in $points){
float $pos[];
vector $dir;
//would need small tweak to support vertex faces
$pos=pointPosition -world $item;
$dir=unit(<>-$center);
polyNormalPerVertex -xyz ($dir.x) ($dir.y) ($dir.z) $item;
// run for all selected vertices facing away form world ceneter
// no more then rudimentary chek of correctness so be carefull
// what you choose. So only choose vertexes
jooProjectNormalOutForm(<>,ls -sl-fl)
Just run place the proc into file named jooProjectNormalOutForm.mel in your user scripts directory and then put the jooProjectNormalOutForm(<>,ls -sl-fl -type float3) into your shelf as a button. (mmb drag teh text there form command editor) Restart Maya done. Select some vertices and hit the button.
Modify center to match what you need.
Nothing to it. Like i said 6 lines of code i just made it nicer to use with the remaining 3 and put a example on how to use it.
PS: you should be able to modify the center metric to make more sense for your practical purposes in no time.
PPS: it took me 10 minutes to write this form scratch and then test it, and write this post. Most of the timne was spent tweaking the post (id say 4/5 if the time, so 2 mnutes for the code, 1 would have been enough had i not had a typo and got a unhelpfull spill all error).
