what about a button which allows you to see the vertical bar (|) in the outliner when the object name is not unique??
( I heard maya is getting more and more user friendly
vertical bar is a dag path separator. What would be the use of showing it in outliner? Outliner displays dag path as a tree
I import data. Often in the built hierachies identical names are produced. When I work with those objects they have to have unique names. I know I could write a script for that, but it would be much nicer to simply have a visual feedback directly in the outliner if the object name is unique or not..
i dont think your need counts as the most imparative of thngs but you can make this happen ina way with mel⦠tough its a cludge and potentialy slow.
Anyhow i my wish for smarter people in the world⦠alias please can i have ![]()
long names ( full dag path ) are always unique - so whereās the problem?
the problem is that most animation pipelines are connected to unique node names ( at least for movers, handles or whatever we call the animation controlers ).
in a studio i worked before we had a system totally independent by the actual node names.
the tools operated only with hidden flags added to the nodes.
it worked really good, but at the beginning were needed massive coding sessions.
ā¦
a lot more easy is to use the actual node names but duplicated names means messed-up animation tools - pickers, poseManagers, etc. Because in most cases the tools are not looking for the full DAG path ( and that should be ).
there are also superfast scripts checking the names of all the trash in the scene before publishing the assets and bringing a list with the āwrongā ones.
a good worklfow can avoid most of the naming mess.
but i agree - the outliner should help us to work around this problem.
would be good to have differently colored items if their names are duplicating other stuff.
simple scripting can help us to immediatelly select the other nodes with same names as the selected one ( or outliner could bring this out of the box ).
Im not against the fact that you could flag things in outliner, but itd be better to let the operation be more general so that users coudl script whatevr marking they wanted so that it would be a proc that genarates them a bit like filttering. (note you can easily make a filter like this so that ouliner would list all duplicates).
Another example could be you marking all tranform nodes that have y values higher then 5 red. because thetway it owuld be more usefull in the end. who know what itd be used for.
my wish is still for smarter users its not personaly against you ist just my wish.
QUOTE
Why is it you feel the need to use the short names in the first place? I mean fo the computer its all the same. I dont se whats the limitting factor?
Is it because your pickers rely on some global variable thats set every time you reload the scene. because i do have a more elegant solution for this (for example final rig uses this and i must say the implementation is a bit badly tought).
OR i can undertsand taht a problem might arise if you import another file with the same time and at generation time you didnt use long names so its not aware now that theres two of them. I mean this is also very easily resolved without needing to ever bother or notify the user.
I dont se what benefit you would get form notifying users with thisng tehy ultimately dont need to be aware of.
Edity oh it dawned on me why you wnat to use short names⦠its because your objects might change palces in hiearchy. Yes no biggie this is easily solved too.
most of the users are smart enough, they are just not that technical, which is all good.
not so far ago i got the same idea for general filtering in the outliner based on rules.
never finished the toolset ā¦
the problem about full DAG path and animation ā¦
usually the animation pipeline relies on generic tools, searching for given strings inside the nodeNames in the scene.
When animator is pressing the button āpleaseBuildMySuperSpecialAnimationUIā, a tool goes trough all the nodes searching for specific strings and builds the animation UI and other tools based on the so found data.
If there are duplicating names then which node is the needed ( right ) one ?
You can see - in this way the workflow is easy and consistent. The riggers are only rigging, instead of rigging and then tweaking the animation tools to support every single character. The animators are happy too - the UI on front of them looks and behaves identical all the time.
The other way is to build your own navigation system - a lot of extra work, than just renaming few nodes of some of the assets to keep the naming conventions.
QUOTE
Yes i understand that , thats what ive been doing the past 4 years. But what your saying is that your code breaks just beacaue there two nodes with the same name, then that means it does break whan the same identifying part is present too! Infact its very prone to breakdown. Then i say your tools arent generic enough.
Thet does still not explain why you MUST use short names, all that info is part of the long name too!
I mean the parser does not need to be horrendeously stupid. Let us suppose that you have two contolls called hand-cntrl now then is proceeds creating controlls if it encounters a duplicate name no prob. Since the gui allways binds absolute names to its controlls theres no way of this causing conflict for the contoroll itself. And if it subsequently encounters a hand controll it goes ahead and builds a second hand controll. It now also knows incidentaly that theres 2 hand controlls present so it can now go back and correnct the naming to reflect the fact that the second contoll belongs to the left hand and the other to the right, and in the case of a 12 handed moster it calls it the secondlowestleftbehindhand because thets what the hierarchy indicates.
now if i added another similliar character it would also incidentaly know that the other hand belongs to bob and the other to lisa.
However your apprach seems to indicate that you somehow make the binding to the ui in some permanent fashion that does not account for changes in the scene. For example tahts hwo final rig in is done and its way badly designed in this aspect!
how do i solve it. Well i allways scan the base characters a new every time they are loaded (i can easily do this with a scriptNode), infact i also present the user a option to rescan the characters just incase i change its structure during the session so if i indeed cnaged the hand to stick in the back for some reason i just tell the ui to update. How do i identify the characters? By Name (tough i also sometimes use sets or attribs to do so), but even the characters name does not need to be unique, because i can allways identify the namespace/group it resides in. and it isnt slow ist fast enough for the user not to notice the difference.
i mean even if i had 100 hands i can easily make a script that can figure out where it belongs even if its not in the same hiearachy trough sets.
But sound like your base identifying sceme is much like finalrigs flawed in the core. No offense.
hehe, look, iām not really sure what is the āfinalRigā thingie you are reffering all the time.
and yes, the animation tools are rescanning everything for every session.
in fact there are scriptNodes doing this automaticly - just hit the load scene button and all the crap will be read and displayed automaticly and it is stable - just the rigger must make sure that there are no duplicating names ( which happens automaticly ).
Long time ago we had the conversation for and against the naming thing.
people have been smart enough to stick with the simple solution.
scanning the heararchy ( or other advanced techniques ) is the easiest way to screw yourself up in the middle of the road.
tokenizing and analizing ⦠analizing and tokenizing ā¦
the rigs around are overcomplicated enough to be scanned that easy.
thatās the reason for my initial post - if Alias bring a little smarter tools for naming management without the need to code this or that, then this will be really helpfull for all of us.
in general it is really simple:
using the nodeNames to manage your scenes is the most efficient way out there, just because Maya comes with tools prepared for that. if people need better management control based on names then i cant see the reason why Alias should not help them.
ok, i enjoyed the conversation, but lets go back to work.
Who said anything about tokenizing? the syrtem i use is uber simple. I dont undesrtand why youd need to tokeneize things even if ther was a duplicate name.
I dont realy understand how chnaging the otlinerw twill make naming more manageable?
i cant understand how you cant understand that ![]()
simple coloring in the Outliner will help me easily to recongnise important for me nodes - in our particular case here - nodes with indentical names.
Tokenizing is needed to figure out where in the hierarchy is located a given node of course. Why - thatās another long story we dont need here.
btw. after the news about Autodesk and Alias i dont think our whishList discussions matter anymore ![]()
QUOTE(thraddash @ 10/05/05, 02:22 AM)
i can understand tthet you could get visual ffeedback easier in the outliner but in any event thats one of those half stupid solutions wher in order to manage things you ask users to manage things more. BY demending them to chek their outliners. for duplicates. Why cant you just tell them they have a duplicate find it and let the user sugggest a cange name?
Its one of those thinsg that people find easy to understand wold work, but isnt necceserily anywhere near a optimal system. I mena what happesns if the uer has so much stuff in the outiner he does not notice theers a duplicate. You cant serously say that needing to find it manualy is thet right way to go!
I would gladly se coloring of nodes implemented since i would have other uses for it. Along the way would be nice if you could populate the outliner with any tree stuff you generate too. Thisway the outliner could be used as a visual hiararchy for ui designer codes etc etc.
QUOTE
[snapback]216425[/snapback]
No its not! you can allways ask maya to provide that info for you in a manner that uses no tokenizing! You CAN do it with tokenizing but you do not have to.
