Vertices Crossing over when Merging Edges
Hi Guys,
I’m modeling a human female and attaching a hand to the forearm, I’ve done this many times before on other models… but for some reason this time when I go to Merge Edges after a Combine, some of the edges do not appear as available to merge.
When I do try to merge two edges that appear as though they should perfectly align, they merge, but the vertices cross over and I get a pinching effect. Anyone ever encounter this or have an idea for a solution?
Both pieces of geometry both have 14 edges, and I’ve aligned all the vertices so that they are close. I’ve deleted history, even tried exporting the body and hand separtely and then re-importing them together. This is kind of frustrating
!MasterFool
Hi Guys,
I selected the faces of the hand and reversed the normals, then it worked fine. Never had that happen before, better prepared for next time.
Edit Polygons> Normals> Reverse
Hope this helps someone else.
!MasterFool
A good way to spot that is to have backface culling switched on.
Thanks,
I didn’t know that, I’ll toggle that in one of my older files and see if it works out.
Wow, that really looked different, thanks for the tip.
!MasterFool
