QUOTE(the dragon @ 02/21/08, 04:36 PM) [snapback]281543[/snapback]
thank you for your help! i put it to the test and it works great. i figured how to delay the video sequence until the camera renders the scene with the video: it's just a matter of running the animation to determine the time before the scene and then adding blank frames to the video material so that it synchs perfectly.
thanks again
You could also render to TARGA files to use to put back together later in post w/ Adobe Premier. That way it'll be easier to time the video playing on the tv, if you cut scenes, it be real easy, but if it has no cuts and is essentially a walk through, then your way would work fine.
