Visibility issues (renders black matte)
i have animated the visibitlity of a series of object over 200 hundred frames. when they render (using batch render, they render fine as single frames) they come out as a flat matte black finish as opposed the white i have assigned.
i have already tried unchecking the "prune invisible parts" under the performance tab of the mental ray render globals, and that works, except that it then renders the shadows for each of the objects regardless of their visibility. im in a serious time crunch, so a fast response would be immensly appreciated. thanking you all in advance.
I dont have an answer-just the same problem. Any suggestions from the regulars? joojaa?? anyone???
