Volume/surface to a curve
I think I brought this discussion before, but I can't really seem to get it to work.
I want to have a small string between two objects.
I used two locators + a linear curve (2 CVs).
I connected each connector to the each end CV on the curve's shape. Now the locators can move independently with a string stretched between them.
However this obviosly does not give anything renderable. I need a surface.
I tried animated sweep, which in this case is just like a loft between two nurb circles. So I tried to connect two circles to the curve and/or to respectiv locator. Then I have problems with the angles (rotation) of the circles (this would solve it (with a loft) otherwise), I need to have the normals of the circle to point towards each other.
Help!
Make a surface, then bindthe points to clusters, create a curve on surface between theese extrude a circle along that curve (use mel to be more precice)... now you have controll over the rotation. If you rotate the cluster the extrude will rotete too.
Hi again,
I'm not sure I totally got what you tried to say, but you somewhat lead me into the right direction.
This is how to do it:
Make a nurbs cicle at origin. Make a linear curve from the origin and up (as a normal to the circle).
Select the circle and curve (in this order).
Then, Surface/Extrude/Options.
Set this to Tube, At path, Component, Profile Normal (the rest as default). - Extrude!
All set, now you can move the two end CVs of the curve independently, with the surface following AND the geometry is maintained (the extrude keeps its circular shape).
Now it's piece a cake to attach each Curve CV/endPiont to separate objects.
Btw, I managed to get this to work with curve, cylinder & wire. But wired objects don't duplicate very well (they loose some of there nodes, which you have to manually connect for each dupl). Anyways, the extrude way is a much more solid solution for animating!
Cool Beans.
Yes welll i wasnt 100% sure what you wanted to do...
But what i additionaly wanted to say was that you should consider using clusters for the points instead of connecting to locators since that is what they are meant for. Altough nothing wrong in your implementation, it was just a side point.
Yes, I got it to work, but it for sure was a pain in the butt to get the locators to stay with their parent objects if the parent object had parents them self (since their translate values don't change when parents and grand parents are moved).
Had to make an expression adding all parents translate to the locator.
Well, your hint about the clusters made life ALOT easier!
Thanks!
Well you could parent the locators but using clusters is the right way to go!
