What determines the life of a voxel? In my billowyish smoke simulation the smoke dies off way too quick, i cannot find anywhere in posts or docs that explains the voxels life span.
Another thing i noticed, is having an empty fluid container in a scene dramatically slows down the playback. Seems like an issue to me since nothings happening and there is no voxels to calculate.
Voxels aren't like particles with lifespans. they are containers of information, the smoke you have is probably disipating to fast, it's hard to say, there are many reason why that could happen though. In your shading tab check your opacity graph, is it on any of the nodes animated? Are you useing a preset/visor file? If so I can quickly look ar it and tell you specifically.
Again its a hard question to answer since there is no lifespan of a voxel. Ducan explains it best of course. As I understand it, its a grid of containers with information that moves between containers, all containers are always there and never move, just the information between them. So your density is diffusing or dissipating too fast, the first things that come to mind are:
emmiter keyed
opacity graph
is fuel set to dynamic grid (fuel might be burning up your density if it is)
does it move out side the container (sometimes hard to tell try haveing all the bounrdys set to both to see if that changes anything)
there are others but I believe you would probably have thought of them, like transparence ect. Again if you are useing a maya preset/visor file I'll be glad to look at it to figure out how they set it up, and why it "dies" off so fast.
Oh and empty containers? Don't know, but if you set them to "disable evaluation" under Dynamic Simulation you won't have that problem.
Well i kidna started wit hte 3d nuke one, but i changed everything on it. I have nothing animating on the opacity, all im using is density so there is no fuel. I have dissipation set to 0. Now, when you say emitter keyed... i have the emitter turn off once i emit the amount of smoke i desired. Because thats the smoke i want to stay there. But it shorly dies there after shrug
does it die near the top, in the middle, near one side or the other?
-if you turned up the turbulence str, or speed it might push the density out of the container
-your texture is might do it, if you have something other than "1"(or something like it) set to your opacity Tex gain
-I once had the problem that the fluid just disapeared what I did was delete all the keys in the incandescence (I did this b/c I didn't really understand the incandescence at the time) I guess you can try that for the hell of it, I think it fixed my problem once. again it makes no sence why that might work, but if you are trying everything try that too.
In your graph editor, what all is keyed on your container?
Tubulence Str
Incandescence1-4
and texture time?
If the density is fading too fast, it is likely a high densityDissipation value, or possibly densityDiffusion.
Duncan
Yeah the odd thing is, its neither both are set to 0.
I played with settings a bunch and it seems to work now. Something might have been wigged out. Still not exactly sure what caused it. Only major things that changed was isntead of using just density with a high bouyancy, im using temperature instead.
Thanks for all the help guys!
try this to test if the density is going out of the container...
set your X,Y,Z bounderys to both.
Its a big container, everything shoots from one side to the other. So its all inside the container.. doesnt get really close to the edges.
when I have fluids that need to go a distance, I cache them at an over sampling of 4 or 5... and make sure you uncheck the boxes you don't need to cache, like fuel, color, and temp(you mention you didn't use temp) that will create a lot more fluid in the conatiner and a different look, but might be the solution to your problems...
It's a tuff one, let me know if that helped at all.
