Good afternoon. I'm from Russia. Poor spoken English. I have the tablet bamboo A6 http://www.creaturedesign.org/files/userfiles/u176/Bamboo\_Overhead-Angle.jpg tablet has 512 levels.Mudboh in 2011 (the 64) sp1 not working levels are pushing the pen. How to whether I draw a mouse. Driver is installed from the disc that came with the tablet. Running Windows 7 (the 64). I tried to install the driver from the official site http://www.wacom.eu/index2.asp?lang=ru&pid=29&gm=1 chose vin7 and bamboo, my model bamboo MTE-450 whether I made a choice from the list? When you install these drivers tablet works quite correctly, works with them 1 / 4 of the screen, driver settings are correct.plizz help solve the problem.
isn't there a setup in mudbox to enable or disable the use of the pressure ?i can't remember but i would check that first after testing if the pressure works in photoshop
hope it's helps
mudbox to install as I understood there, but their inclusion did not change anything. In Photoshop everything works fine, the sensitivity is present. Just does not work the sensitivity of the pen in Maya.
Now put the version 2010 there working pen pressure sensitivity. so the problem in 2011 version
I was wrong. sensitivity to touch of the pen works only in 32bit versions. hence the problem is drayvers.u me on the drive says that drivers 32 and 64bit
Thank you all, I solved the problem
Error: Backend Fetch Failure
