Ok so if I animate the character going across the screen instead of on the spot, what if I need it to run on the spot (CYCLE) now, is it as easy as translating the poses back to where the first pose was? (ie. perhaps over the origin?)
And if so, would i need to tweak? (the section in the Animators kit seems to imply that you should animate it across the screen, and then "figure out a cycle"? But if you just translate poses back, there's nothing really to figure out right? I know the book applies more to 2D..)
Also, is this true for both runs and walks? Do the run across the screen (2 steps), and then translate the poses back?
