Watching videos on Linux
What do you guys use to view AVIs, MPEGs, and MOVs? Is there a unified tool for all those, or should I just look for players for each of those separately? What about the multitude of Codecs that AVIs and MOVs use?
I prefer xanim and xmovie. Both are good for me.
rokl
Try Mplayer. It uses the Windows codecs, so it can play many different filetypes. Gmerlin is also good. You can also check here.
Okay, I got MPlayer to install (last time I tried I had no luck, I guess the current build is more mature).
It’s working splendidly otherwise, but the popupmenu doesn’t work.The menu appears, but I can’t pick any of the options. I can only use the buttons on the player skin, so my options are a little limoited. I can play normal size and fullscreen, but not double size.
Any idea what might be wrong?
