@- the mental ray settings in BOTH SI 2.7 and 3.9 are: refl. 2, refr.2, sum 4, also the antialiassing is identical
what about the other settings?
@- I'm rendering on the same machine, but I never install 3.9 + 3.9 together, I just tried it before Windows reinstall...
Aha! here's the problem - you haven't done an apples to apples test. You used v3.7 on the original installation of windows while using v3.9 on a re-install. In order for these test renders to mean anything, you have to do the tests for both v3.7 and v3.9 under the same conditions. I bet there's a network gremlin in there somewhere.
@- Paths: I always run it from one database where all PICs are. No network stuff or so.
To mental ray, all paths are absolute, so whether they're on the local machine or across a network makes no difference. If any of the drive names changed or were modified not quite right by either you or Softimage|3D, then some unnecesary could certainly be introduced.
@-which other settings could have been changed by SI 3.9.1?
Quite a few, but I wouldn't tinker with any of them until some apples-to-apples test renders are performed. You're gonna have to put v3.7 back on the machine in order to do this.
@BTW, I also tried out my other scenes on a P3-1000 MHz(www.3dartist.f2s.com) and here are the results (first is SI 3.9.1, second is SI 3.7):
Something's wrong here, these times don't match those listed on the website.
Matt
Matt Lind
Animator / Technical Director
Softimage|3D
Softimage|XSI
speye_21@hotmail.com
