oh,i have no idea about noise function.Not only about its use,
but also its means.
with regards.
but also its means.
with regards.
For a value x the function noise(x) returns always the same number. So you would use y = noise($currentTime) to get a different y for each frame. The special thing about y is that it is not completely random, so that the value of the next frame is slightly related to the value of the current frame to avoid the "jittery and jumpy" behavior of y = rand($currentTime)
ball.ty = 5*noise(frame/10) = amplitude * noise(changing value * freq)
Taken from MEL Fundamentals
QUOTE(Daniel_Faus @ 03/15/07, 06:40 AM) [snapback]262239[/snapback]
thanks for geting back to me
what behavior ?
You'll see.
-- edit --
sorry for that answer, but you probably know that sometimes "a picture is worth a thousand words".
I could have created a scene for you which shows you the difference, now that you have your answer but just can't visualize it. But actually if you really need the noise function because you think that rand is giving your problems, you probably knew what I was talking about. On the other hand, if you were just interested, you could have just created a testing scene by yourself or typed "noise" into the online help which has got some images in it to get a better understanding. Yes this board is really an excellent place to find help, but it won't do the homework for you.
http://www.mrl.nyu.edu/~perlin/doc/oscar.html
read the making noise slides
heres another:
http://freespace.virgin.net/hugo.elias/models/m\_perlin.htm
PS for those of you who think computer graphuics dont have history noise comes form way back 1983
