What To Get First
Hi all.
i registered to highended few years ago, but this is my first time joining the forum.
before...i use 3dsmax, and now i really want to learn maya.
what should i do to learn maya for the first timer.
i ever read and follow many tutorials on the web..i just thought that i still not completely understanding any tools in maya.
any help will appreciated
thank you
  • Crate a cube open up hypergraph and grapth the history. then do some operations on it and the changes in the chain.
  • Read the manual section on maya gui.
  • learn to use the keyboard. (most notaby shorcuts shift, ctrl, alt, z,x,c,v. a, q,w,e,r,t y, 1,2,3,4 the most important ones s d g y and space, b and rmb). go to the shortuct editor for the INSANELY long full list
  • Learn academics, maya was designed by a forum of very academic people. This is why maya has separate modules that do exactly just one thing. Those things do what they are supposed to in very academic way so a curve analysing tool, as for example path anim works just exactly like the formula described in your caclulush textbook, and they dont care about your feeling.
  • Maya is a do it yourself program, a bit like its not for every man to build his own house. Mayas been designed for those of us who can take charge of their own problems, or work closely with one. Being academic helps here because you can find the inner workings with sufficent amount of contemplation. This mean sthe solution is not allways optimal for the FIRST apparent use. It is however workable into other things. So just because its a animation tool does not mean its not a good tool for shading.
  • whatever you do keep reading the node refence. It contains the truth of how maya is used. NOT the other parts,
  • Your not going to learn all there is to learn about maya! Because that would mean to learn everything about everything.
  • highend3d is got full of recommend tutorials.
    is there any web that your can recommend me for best maya tutorial
    thank you verymuch
    QUOTE(amek @ 07/18/08, 04:34 PM) [snapback]288519[/snapback]
    best maya tutorial
    Best depends on so many things. To be honest im not sure ivee ever seen a perfect tutorial. Ive just seen adequate ones. Hell ive seen balant errors even in the best of info materials such as gnomon cd's
    So no i would recommend you read the manual and not do tutrials. Really its all there. A tutorial is more like a feelgood program to make you feel good about yoruself. But if you TRULY want to learn something you read the manual (yes ALL of teh webpages).
    Learning maya has some free starter tutorials. Not perfect last time i searched i didn't find a single one that wouldn't be misleading but... I guess it the same kind of situation like the way you were taught how the tide forms in school (its just the banal example of a lie theres man many more), one needs to make some well placed lies to get people going.
    Anyway you can keep on making tutorials forever and never progress beyond certain points.
    ok.
    thanks
