can someone explain to me when i use either? i really want to get like panic room and fight club results for the cg but i am not sure when to use which and when do i use both i hope someone can just like tell me a exp? thanks
GI usually is outdoor lighting.
I haven’t used Mental Ray yet (this afternoon I will I hope).
But I think in MR you use GI for Radiosity (ie colour bleeding/light bouncing) but you use FG (Final Gathering) for the skylight/skydome type effect.
I’m not 100% sure though.
Global illumination simulates the lighting phenomenon that occurs when light reflects off objects and causes the surroundings to inherit some of the object’s color.
A good example of what global illumination brings to the scenes that you create in SOFTIMAGE|XSI can be seen in a photographer’s studio. A photographer uses reflectors and diffusers to illuminate the subject with reflected light. The color of the reflector colors the light bouncing off it and onto the subject, thereby coloring the subject. Global illumination is a simple solution to achieving real-world lighting: When global illumination is used in a larger scene with many objects, you can simulate how real light affects every object it touches, taking into consideration their proximity to other objects, their distance from the light, as well as other lighting in the scene.
Final gathering computes single bounces of indirect light on diffuse surfaces. It gives you details in areas of the scene where there are many edges and sharp light variations. It can be used alone on scenes with a lot of direct light or in conjunction with global illumination. The rule of thumb suggests that if the strength of the direct light in a scene is greater than 50 percent, then final gathering can be useful.
