Where's my TwinView?
i have a GeForce 3 ti 200 128mb card. This card also has a dvi output, so i bought a dvi adapter and hooked up two monitors.
I get the same screen on both monitors, but when i got to find the twinview settings, so i can enable multiple monitors i cant find the twinview tab.
Is twinview a seperate download or does it come with the drivers downloaded from the nvidia site?
Please help, till now ive been using an additional pci card, but i want to be able to run hypershade and othe open gl on the second monitor.
thanks in advanced
jack
“Twinview” is only available on Geforce 2 MX### and Quadro 2 MXR, EX, based cards.
“Nview” is only available on Geforce 4 based cards, even then, finding one that actually supports it is tough.
So, you’re essentially [censored] out of luck.
all of the geforce 4 cards support nview; you’d just need a DVI-VGA adapter. However gf3 ti series cards don’t support twinview or dual monitors. if your card supports it you’ll see the tab for it.
does twinview from geforce 2 support two monitors? I have an RCA TV output from the card. I don’t think I can turn this signal into an actual digital signal can I?
Oh well Geforce 4 here I come.
