Why do fuilds move only on one side?
I have been working on a explosion and right know I am working on fire, on both the occasions I see this fuid move after some time on the right of the box.
Why does it do this?
And please can some one help me in controlling this fuilds.
Thanks
are you using Maya 5 by chance?
As mentioned, if you are using an older version of Maya temperature turbulence has a directional bias along 1,1,1(diagonal). Or if temperature turbulence is zero then it is a different issue. It is important to understand that the fluid models an incompressible flow.. it does not behave like particles with regards to forces. If the box is closed( boundary settings ) then the fluid must swirl around inside the box.. it has nowhere to go. Also pushing in one place pushes on other places. (Think of the fluid container as a tank filled with water where the density is like colored dye in the water)
Duncan
Thanks Duncan
for that bit of information
I have closed the boundaries and it works.
