Why Does My Fur Glow?
I have a model with orange fur. The fur looks fine in a lit scene, but in another scene, in which the lights are turned down, the fur glows. While trying to figure it out, I rendered a scene with a point light with density set to .100 and the result is just the fur glowing.
I can't do a scene with shadows and darkness when my model's fur is glowing.
Can someone please tell me how to fix this?
Thanks
Are the Base and Tip Ambient Color values non-zero perhaps?
No, the ambient colors are zero
No shadowcasting?
I can't figure this out. If I import my model into a new scene and use an ambient light, the fur looks fine.
The scene I'm having the problem with has a spotlight, ambient light and point light. It's for a children's Halloween book. The moon is casting shadows across the ground with trees. Everyting looks great, except the fur on my model sticks out. It's lit like it has a glow attribute.
As far as shadows, the spotlight and point light are both using depth map shadowing, yet, it doesn't matter that the light is hitting only one side of the fur. The whole fur is lit bright orange.
QUOTE(DJsix @ 06/17/09, 03:10 AM) [snapback]309634[/snapback]
ambient light
Bingo, that is the reason. If you want to be a pro never use ambient light for anything.
