I am trying to increase the sampling on some glossy objects in my scene without increasing the overall sampling in the entire scene. I set the min and max object samples to 2 and 2 in the mental ray section of the attribute editor for my glossy objects, and i set the sample settings to 0 and 1 in the render settings. The problem is when I render the scene comes out looking exactly as it would had i not changed the per object samples on my glossy objects. Whats the deal? why wont this work, and more importantly is there a way to adjust sampling on a per object or per material basis?
Hi, it is not possible to increase samples on DGS shaders. You can use any maya Shader and turn on reflection blur and increase the sample on those shaders.
bummer, thanks anyway
Actually it is totally possible to do what you want. Its just that the globals and overrides work in same range and override each other.
So if you put a override for a object to be 2 4 and your global setting is 0 2 your object will actually get a a override of 2 2. In order for you to be able to put a 2 4 override you'd need to put your globals for 0 4. Off course then you'd also need to override ALL NON overridden things to 0 2manualy. Same applies to the lowest value. The globals override the range you can set.
Theres even a second way of doing this and tehts to use the oversample lens shader wich also could work in similar fashion.
hmmm interesting, thanks again Joojaa.
