Hi all, I was still playing with some mel scripts two days ago but how come I can't even launch it now?? I did copy some spiral mel scripts to the "others" folder but I don't think this will make the maya unable to launch any mel script now.
Thanks a lot for the response! I unzipped the flies.mel and copy the mel scripts to the Maya3.0/scripts/others folder, it was playing fine for the past few days. After that I copied another few scripts to the same folder such as spiral.mel, spiralSurface.mel and others which I can't really remember, it happened once the computer prompt a message saying whether I want to replace the spiral.mel in the folder and I clicked "yes". From there I can't launch any mel script anymore!
I know it's kind of odd but I am sure the path and case is correct. Maybe I should just re-install Maya and recopy the mel script one by one to dignose the problem again.
I t hink you need to reinstall maya.. just move the scripts that you added recently by date fromt he others folder and then see if Maya is OK. Then add the ones you need back and see if they work.
