I realise that I’m just embarrassing myself on this board with my 3D work. I shan’t make the mistake of posting here again.
btw, ElectronicOutlaw is a scum-sucking piece of [censored] who uses the anonymity of the Internet as an excuse to act like a dick and be rude to people. I bet you couldn’t do better CG than me if you tried you [censored].
Edited by scotth on 08/07/01 03:25:19 AM.
i think the eyes need to be pushed back a bit, it seems a
little too forward… and the upper lips is too pale in
comparison to the bottom one, but other than that i think
it’s really good. specially the sweater… i’m thinking u used
a regular file texture for the sweater, right? it looks good…
i’m assumin u used paint effects for the hair? it’s a little
too bright… i had the same problem before where the
face of my character was perfectly lit, but the paint effects
hair was lit way too bright. i tried to do light linkin but
i realized that paint effects aren’t affected by light linking.
u might want to change the lighting for paint effects by
turning off the option in the paint effects attribute to be lit
by existing lights, and just specify a specific lighting scheme
just for the paint effects so that it won’t be lit too bright…
pretty good…
Err.. scary.. I can only assume that youa re going for something stylized because this girl’s head is not realistic.
I would say that the forehead is too large, The eyes too big and the bridge of the nose is too flat and almost in the same plane as the cheek bones. The lips have a good shape to them but the look like the curl out in a very unnatural way… I fi could see them from he side I would expect to seem them curl up and almost start to turn back on themselves. You should post a side view. Also the temples have too sharp of a pinch in them.
The skin shader is okay but a bit like plastic. The tones are good but the specualr is a bit too flat. Also the bump seems too large. The eyebrows look like they are black stripes and the hair could use less specular.
The upper lip is too bright and the eyes have too much eccentricity which makes it look like she has cataracts.
