Why such bad ranking
Hello all,
I was excited to receive my new system yesterday after waiting a month for it. To my dissapointment i ran the test render and got a time of 1 min 30 sec. Many of the entries on the database have eather the same set up or less and are ranking much higher. Can someone tell me if there is some kind of tweak or something that i am supposed to do. Here is the system:
Asus A7M266-D MoBo
2 Athlon 1900mp cpus
1 Gig DDR Ram
Nvidia GeForce 3 ti200 (128mb)
Please let me know if the render time should have been higher and if so what can i do about it.
Thanks in advance
Which test is that? And what is your os?
the test is the one posted in the test center section of Maya on this site.
I am using win2k
well some simple questions to answer…
  1. Are you rendering from the command line instead of in the GUI?
  2. Have you closed/quit/exited from everything else running on your system?
  3. Are you using the -n 2 flag for rendering w/ two processors?
Well, let me start out by saying that i am very new to maya, so please excuse my ignorance.
I followed the instructions on the rendertest page and went to batch render and set the amount of processors to two. so i guess that would be using the GUI. I do not know the way to do it from the command line, can you explaine please?
I did exit all programs before rendering.
I am not familiar with setting the -n 2 flag for rendering, please explaine how thats done. thats probably why i got a higher time.
I really appreciate your help
render.exe -n 0 rendertest.ma
This will render the test file using all available procs or in this case 2 procs.
The console is in the accesories folder in the start menu
or hit control alt delete then click on the applications tab and then new task and then enter cmd.exe and hit ok
then type the above command in and hit enter.
just a little correction to gmask’s post b/c i know what he was trying to say
in the START-Programs-Accessories there will be Command Prompt thats what you should use to render.
We swap the word console or shell w/ command prompt just b/c of our experience across different systems but I wanted to clear it up for you since you are new.
At the command prompt type maya -render and you will get a pop up of all the flags that you can use in render. As stated above to render just type render filename.mb -n2 and it will render you file (filename.mb) w/ both processors and will run off your Render Globals unless you speicify additional flags.
Happy Rendering
just wanted to say that I got a 1:04 time without the command line thing. I think using a batchrender tool like smedge or muster should produce equivalent times. My expierence is even, if you start a batch render from the maya main app, and then quiting maya, the batch process runs on and has free memory so it should give you the same result like sarting from command line. Or am i totaly wrong?
Yeah you can do that.. it is a good idea to get familiar with how to do it from the commmandline though. I have found that with Muster for example it’s error reporting is not very helpful and running renders from the commandline/command prompt/console/shell helps with debugging.
