Wildcat 4105 glitches
i just purchased a wildcat 4105 to run on win 2000. it seems to be working fine, however my shaders look negative in the preview window but fine in the hypershade window. it is a minor inconvienance, but when i apply colors in the attributes window, i have to watch the hypershade to see the results. the preview will show that i am applying a red color when i am appying blue and flip colors around on iff files, ect.any ideas? also, i am getting some degrading in renderings. objects render with small black faces on them as you render from a distance, but perfect when close up. i dont think this is a hardware problem, but i am not sure. thanks so much for your help.
I know this isn’t a very helpful response, but I have a 4105 and I’ve had enough miscellaneous problems like those you describe under Win2k that I went back to NT. Although I never got a straight answer on the various issues, I came to the conclusion that the 4105 just doesn’t work very will under Win2k.
Sorry,
Paul
