Pretty impressive if you ask me…
Here’s the link
Here’s the link
geez..thats hefty
oooooooo…i want one…price?
probably only comes with a system../
its how the others seem to have been sold..
damn wicked card! one question though: I understand that this is a high-end workstation-class card & not destigned for gaming or any other such necessities of working as a 3D artist, but why no implementation of DirectX 8? They’re still stuck on 7 for some reason. Some of the features in 3dsmax4 for example require DX8, yet this card is still qualified.
Any thoughts?
doesn’t max also have an OpenGL mode? I know OGL is where the wildcat shines.
If I remember right, DirectX 8 requires that you support Pixel/Vertex shaders. Infact I don’t even think my Geforce 2 MX is even DX8 compatible…
As for 3dsmax, the D3d is mostly just a tech demo for Geforce 3 cards. Beyond that, most people I know never use it.
From the .pdf data sheet:
"Six T&L engines for performance and programmability
Six highly-tuned T&L engines deliver outstanding performance - especially as scene complexity increases. And, since they’re fully programmable, you can work with the latest innovations in graphics APIs by means of a simple software driver update. So, you protect your graphics investment and benefit from more power on the desktop."
Does that mean it has what others call vertex shaders? And six of them, as opposed to Geforce 3’s one and Geforce 4/Xbox GPUs two?
Regards / Erik Spr
T&L stands for Transform and Lighting
Transform is as far as I know for IK chains and other deformations
Lighting is obvious.
You’re thinking of Texturing Units on the Geforce and Radeon cards, not T&L.
If I remember correctly, I think the “transform” part is math that sets up how surfaces and changing surface normals are computed (extracted?) early on in the realtime rendering pipeline.
Calculating “transforms” in hardware is good, i think.
I have no idea how the “L” in hardware T&L is helpful.
I’m pretty sure that both of those optimizations are available via either DX or OGL.
kiwi
looks like you can only get em through
compaq or HP
make no mistake - opengl is most definitely the mode of choice! i’m just really interested in why 3dlabs don’t support dx8. is it because they think it is far inferior to opengl & not worth even considering in a production environment? i know that’s the way that i think about it! in contrast to many manufacturers who seem to want to add as many bells & whistles to everything they produce - putting in the latest & greatest features of everything remotely related to the product but by no means increasing the productivity of the device, 3dlabs seems to stick with what is good & solid & works. if their cards were more affordable, i would most likely be using one of them instead of my geforce 'cos all the apps i use & all the games i play either support opengl or don’t need dx8.
Kiwi: L in T&L is useful in previewing the lighting. Essentially it’s hardware vertex lighting. The magic catch 22 with vertex lighting is, you need a shitload of vertices for it to look good. The Wildcat 3 should be able to do that… with textures being enabled at the sametime… well that’s I wouldn’t know.
Thumpa: Well consider what market 3DLabs aims for. The only reason they’ve even bothered with DirectX is cause of the hordes of Wildcat 2 owners complaining about the lack of it.
Besides, I’d doubt you’d use any 3dlabs card for gaming. They lack the fillrate and texels/sec to truly be playable with almost any game.
There doesn’t seem to be any reason for them to put much effort into DX since OGL is the way to go for the intended usage of the card.
But it would be interesting to see how fast the 6210 would be if it WERE optimized for gaming.
Thumpa:
I think there was a little talk on the Discreet Forum about the Wildcat (5000 series) and their performance with Max. I remember Greg Hess and another person saying that the Wildcat’s with Max did not meet their full potential, possibly because of the way Open GL is implemented in Max. In Maya, Soft, etc., they were saying that the Wildcat’s were, indeed, very fast, but in Max, the extra power was wasted. Go to the discreet Forum/Hardware and search for Wildcat cards. It should be there somewhere.
Mahlon
The vertex shader is a programmable peice of logic that takes the place of the fixed function T&L engine, thus it can also do a whole bunch of new things, like tesselating higher order surfaces, skinning on bones etc. See for example http://www.tomshardware.com/graphic/01q1/0…eforce3-02.html for more info.
In the paper about Wildcat 6210 they say it has six “fully programmable” T&L engines. Does that mean it can do anything the vertex shaders of the geforce3/geforce4Ti/radeon 8500/xbox/etc can do? Just how programmable are they?
Regards / Erik Spr
I hear you can actually program them to make fun of the user’s work, -and burn toast.
kiwi
The phrase “T&L Pipline” can be interpreted many ways. They are there and are definitely used by the OGL drivers in the OGL pipline. (www.opengl.com)
Transformation usually refers to geometry transformation only. The lighting part definitely works with textures, but it is not clear if it only works on pre-computed textures, processed with the CPU or if it has texture operators in HW.
Whether or not they are used by the DX drivers is up in the air. DX7 does not support pixel or vertex shaders. it has a “stupider” pipline (a fixed pipeline) (http://www.tomshardware.com/graphic/02q1/020116/index.htmlhttp://www.tomshardware.com/graphic/02q1/020116/index.html)
There is also the unsettling possibility that the Wildcats still do the VGA + “our stuff” overlay kludge. The previous WC’s have a Chips and Technologies VGA chip on them for 2D functions. So Open GL windows from the 3DLabs mojo are combined with the output of the VG chip to give you your final screen.
So the WC III might be limited in D3D land by it VGA overlay chip ![]()
Any VAR’s out there have one and could tell us?
adam…
