Win 2k with Fcheck
I am not sure if this is a Ram issue but at our studios we have to machines next to one another. Dual 600 Intergraphs with Wildcats and 512 Ram. One has NT Sp6 and the other Win 2K with all the proper drivers installed. Fcheck on NT will play back real-time Win 2K is slow as all hell and cannot achieve real time playback. I know 2K has a lot of memory overhead but has anyone else come across this issue?
Anti-Aliased
I have a Dual PIII 450, Oxygen GMX 2000, 256mb of RAM and I have had no problems fchecking frames from my hard drive (which are SCSI - that may or may not make a difference) in Windows 2000. I tested it w/ NT 4 and both play perfectly fine in both.
Are you loading up fcheck through the GUI (Start-Maya-Fcheck) or through the command line (fcheck filename.yuv.0001)? That could speed up things. Other then that I would suggest reinstalling Win2k and see if things change.
Hope that gives you some ideas )
what res are the images?? I dont’ have any problems here previewing images on fcheck, both PAL and 1k. Not very long sequences mind you, takes too long to load over the network!
Running 512Mb RAM and w2k…
I haven’t compared Fcheck speeds, but I’d suspect Win2k is generally the culprit. Just wait till you get a hold of XP Stability vs. performance. Using After Effects to view your renders might seem like overkill, but it’ll definitely do real-time previews.
http://chomxxo.com
