I create window and use command window backgroundColor 0 0 0 windowname; When run windows is creat but the color still be defalt window color. How can I chage windows color?
by the way, the three float value is stand for RGB Am I right? Is it maximun limit to 255? I try to use same command to creat button with color value as 0 0 0 it's black but when I try 5 5 5, it should turn to be the color near to black, but it appear to be very light color near to white. So if it's not RGB value how can I get value of color?
yeah if it was a integer then the value would probably range from 0 to 255 after all the index is a integer value But they kindoff probably wanted it to be compatible with other col9or assignments in maya.
