Bonjour Kidlat,
There is 2 ways to achieve this:
1- Viewport capture
Make your camera viewport display on Depth Cue
Click on the Camera Icon Menu and choose Start Capture
This will bring an output dialog, just set it as you want, then click ok.
This will cause the viewport to render.
2- Toon shaders
You'll have to check the documentation to see if you can do Depth Cue rendering with the Toon shaders. I don't know much of these shaders, so I can't really help you here.
Hope this helps
Salutations - Cheers
Bernard Lebel
