Hi all!
I'm trying to render some models (both NURBS and poly) in wireframe. I know that Mental Ray has this feature but I'm a little unsure about how to go about it. Can anyone point me in the right direction?
Thanks
Matt
Hi all!
Thanks
Matt
This is a good tutorial with sample scenes to download,
http://www.fenriz.org/projects/maya/maya\_toon\_shading\_i.php
I found the TomCat Toon shader plug-in useful using Maya's software render to get a wireframe look... with the wires as paint effects!
This is how Patrick at Toon shade described the set up:
It's very simple to do:
You can solve anti-aliasing problems by rendering at 2x resolution and activating the "enable better anti-aliasing" option in the cartoonshader menu. You may also play with the "3d displace" option on the shader.
Patrick
http://www.toonshade.com
