Is there a new possibility to render wireframes in XSI 2.0? If it is a new shader, would it also work in 1.5?
newton
Bonjour Newton,
You may want to use a toon shader to render wireframe.
But, a more straightforward way is to put your camera view to Wireframe display, then click on the camera icon (viewport's top bar), and select Start Capture. There you can grab a playback from your viewport and save the files to disk. The only limitation is that you can set sizes larger than your screen's resolution.
Hope this helps
Salutations - Cheers
Bernard Lebel
Bonjour Atyss,
I tried the toonshader in 1.5, but it was only able to render in hidden line modus. Also the quality was a bit disappointing. Unfortunately i need big resolutions. Do you work with xsi 2?
bests, newton
No I'm still on 1.5, but I assume that the shader is the same in version 2, if not better.
Have you tried the capture thing?
I know that the wireframe rendering topic has been covered a couple of times on this forum, have you find anything useful?
Bernard Lebel
The toon shaders in XSI v1.x are direct ports from Softimage|3D without any optimizations. That is why some of their functions have been crippled (such as hiding inkline seams).
In XSI v2.0, the toon shaders were completely rewritten from scratch and contain many improvements over the old toon shaders. Including the ability to render true wireframe images showing surface tessellation with controls to hide edges of coplanar polygons.
If you have XSI v2.0, you can also compile the shader case study in the SDK example section. The tutorial covers how to write a simple wireframe texture shader. It will render faster than the toon shaders as it's applied as a texture, but the lines won't necessarily have uniform thickness because they aren't perspective corrected (eg: no compensation made for depth or viewing angle).
If you're using NURBS surfaces, you can use the "grid" shader to render the wireframes. Just set color1 to your desired wirecolor, and set color2 completely transparent.
Matt
Matt Lind
Animator / Technical Director
Softimage|3D
Softimage|XSI
speye_21@hotmail.com
