Hi all, i am trying to create an animation of my car moving forwards and then turning left at an angle of 20 degrees. I have a problem with getting the wheels to turn left correctly at a similar angle to simulate the motion of the wheels creating the turn movement of the car. The axis for turning the wheel sims to be offset, This is why: The Car is grouped together and set to move forward along the z axis for 19cm, I have also grouped the two front wheels together, and have animated this to rotate around the x axis at 360x6(2160 degrees roughly). Then i animated the car rotating left abit at an angle of 20 degrees on y axis, now up to here everything works fine, but i just need to animate the tyre turning left to make the animation look real, so i try and animate each front wheel (with the 2160degree rotation) to rotate a slight bit to the left on its Y axis, but it is all rotating weird on me, any tips or advice?
Would be much appreciated, i have tried using a locator to help but it does not work.
Dan
