Wrap Deformer Hi Res Poly Flaws
I’ve created this cute little penguin animation.
Here is the playblast so you can have a frame of reference for what I’m trying to achieve:
QuickTime File
My problem is that my high res polygon model is not reacting to the wrap deformer the way I expect for about 10% of the animation. The most noticable moments are when the head tilts from side to side.
Here is the result of that head tilt:
400) {this.resized=true; this.width=400; this.alt=‘Click here to open new window’;}" onmouseover=“if(this.resized) this.style.cursor=‘hand’;” onclick=“if(this.resized) {window.open(‘http://www.mps-twcable.com/Temporary/BadWrap.gif’);}” />
Clearly the high poly is getting confused by the two halves of the wrap deformer (since the wrap deformer was sliced down the middle). Those vertices in the center of the high poly seem to be getting double driven only when I tilt the head.
This doesn’t make sense to me. If that were the case wouldn’t all center lined vertices be doubley effected? So that even a simple translation of them would double up as well. Seems to only happen with the head tilt.
I did figure out one possible solution. If I can detach the wrap deformer I could then apply a smooth polygon action to the low poly model. But then I run into the problem that no shader I apply to the former wrap deformer model will render. As much as I try to delete any information that relates to wrap deformers I can’t make it visible for the render.
If someone could help point me in the right direction to make the wrap d work or show me how to turn a wrap d model into a renderer visible model I would be very thankful.
if you have two wraps, then go to the relationshipEditors->Deformers and remove at least all vertices that conflict from one of wraps - this would fix double transformation you’ve mentioned
Alrighty! Got things thunk’d out.
I couldn’t get the “edit membership tool” to function… period. Not sure why, other than the tool would have no way of distinquishing whether to remove the vertice from wrap1 or wrap2.
My solution was under the following pull down menu: Windows > Relationships Editor > Deforms.
Once this editor is open follow these steps:
  1. select your high res Poly or SubD (since that is the Wrap Deformer).
    switch to Vertice mode and select only the vertices in the center row (where the two low res poly models are separated).
  2. In the Deforms Relationship Editor’s right column go to “List” and pick “Manual”. This will load only those vertices you’ve highlighted.
  3. Then go to the left column and click once on the secondary wrap (ie wrap2). This will highlight all those vertices that are in the right column.
  4. In the upper left of the editor window is a Plus and Minus symbol. Click the Minus symbol.
This process may take SOME time for Maya to calculate depending on the model complexity. But once it is done these vertices will no longer be shared by two deformers.
Hope this helps anyone from going through the day of I went through to find this solution.
