XP and Riva Tuner
Anybody able to get Rivatuner to work on Xp with Maya using a gefroce 2 card?
Thanks in advance-
yes I’ve been using it for a while on XP and it works fine
what do you mean does it work with maya though?
Thank you for your reply…that’s good news. I should not have any trouble configuring for Maya right? By the way are you using the latest drivers? Where do I get Riva Tuner it again? I can’t seem to get into the 3d guru website…thank you again
Ohh and what RTh. are you using? The windows 2000 script? I didn’t see one for XP only 2000. DOes this matter?
Woops I mean RTS are you using. What is the windows 2000 antiprotection rts? and what does it due? Is there one for Xp as well?
My apologies for laying all of these questions on you but I am sure that this will help a few other confused individuals as well…let’s get to the bottom of this.
Full guide on how to patch and install the patched drivers in Windows 2000/XP
Ok first of all, Guru3D.com has gone head over heels and has shut down for good. (what a shame, a damn good site it was)
You can always find the newest version of RivaTuner (currently at RC 8.2) at http://www.nvworld.ruhttp://www.nvworld.ru .
The site is in Russian, but the link to RivaTuner is always in English and usually on top of the page. Make sure you keep updating the version when a new one comes out because the author updates the patches to work with the new drivers continously.
Now that guru3d.com is gone I found these couple of links to sites that are hosting the some of the detonator 4 drivers that I have mentioned in the following article:
http://frankenstein.0c3.net/nVidiaDrivers/GeForce3/Win2K/http://frankenstein.0c3.net/nVidiaDrivers/GeForce3/Win2K/
http://www.3dnews.ru/download/drivers/nvidia/http://www.3dnews.ru/download/drivers/nvidia/ *BETTER
OK, now I’m gonna write a complete guide to patching the drivers for all the people that have no experience on how to do this. If you see another thread on this forum asking how to patch the drivers, refer them to this thread please.
First download the latest video card drivers from NVIDIA.com (the 23.11 version currently available there has caused problems in my machine and reportedly in others too). I personally prefer to use the 21.83 because they cause no problems with my configuration.
Next download and install RivaTuner and install it. Make sure you have an application such as WinZip or WinRar or WinAce, you get the idea… Using such applications will allow you to actually decompress the setup file in which the downloaded drivers are packaged. Decompress the file to a folder of your choice and next start RivaTuner.
Go to the PowerUser tab in the main interface and hover the mouse cursor on top of the buttons on the bottom of the interface until you find the one that says “Open Patch Script”. It should be the third button from the left.
Click the button and the “Open Patch” dialog box will default to the directory where you have installed RivaTuner. Click through the “Patch Scripts” folder, then the “SoftQuadro” folder and then… here are the choices:
If you are patching any video drivers that are version 14.4x up to 21.xx, you will need to execute both the “SoftQuadro w2k antiprotection.rts” and the “SoftQuadro w2k.rts” patch scripts on the drivers, where as if you are using any driver that doesn’t fall in that category, you do not need to run the anti-protection script.
The anti-protection script removes any protection that nvidia has put in it’s open gl driver in order to keep it from being used in high end 3d apps (as far as I know) and it is absolutely neccessary to be used in the drivers 14.xx-21.xx because otherwise Maya and any other high end open gl application will crash (sometimes immediately, sometimes after a few seconds).
Ok, when you are ready open the “SoftQuadro w2k.rts” file and select the card “Quadro” version that corresponds to your card
GeForce = Quadro
GeForce2 MX = Quadro2 MXR/EX
GeForce2 Pro/GTS/Ultra = Quadro2 Pro
GeForce3 = Quadro DCC
and click “Continue” on the next window. Then in the new “Open File” dialog box, browse to the folder where you extracted the driver files and select the file “NV4_mini.sys” (it should be the only file displayed, by default). After it’s done, you should see a message saying that the operation was complete successfully, at which point you click the little “X” on the top right corner of the window because you only run the patch once.
If you are using one of the drivers I mentioned above that require the anti-protection script patch, then click “Open Patch” again and this time run “SoftQuadro w2k antiprotection.rts” script, and when the new window comes up, just click “Continue” (there is no card model to choose this time) and browse to the folder where you extracted the driver files and double click the “nvoglnt.dll” file which will be patched by SoftQuadro. Click the “X:” when the operation finishes.
Now you are done with patching the drivers. You will need to install the patched drivers next, and when it comes time to choose the card model, make sure you choose the current model of your card, and not the Quadro version because the patching has been done at the driver level and the the card itself is in no way modified.
For the newbies that have no clue how to install new video card drivers manually, make sure you read the following instructions:
Right click on the desktop and select “Properties”. Click the “Settings” tab and click on the “Advanced” tab. Then go to the “Adapter” tab and click “Properties”. Next select the “Driver” tab and click on “Update Driver”.
When the “Hardware Update Wizard” window comes up, select “Install from a list or specific location[Advanced]” and click Next.
In the next screen, select “Dont’ search. I will choose the driver to install” and click Next again. On the next screen, click “Have disk” and browse to the folder where you extracted the driver files and select “nv4_disp.inf” if there are more then one .inf files that show up.
In the next window, select the card model that matches your card and click “Next” or “Install” (whichever button comes up, I can’t recall) and if Windows gives you a warning saying that you are installing a driver that has not been approved by Microsoft WHQL labs, just click the “Install Anyway” button wait for the driver installation to finish and click ok to close all the open windows. Restart when Windows prompts you to install.
After you reboot, when you go into your Open GL settings in you display settings you will notice some new functions that you can enable. One word of caution though, make sure you have disabled the “Enable Overlays” feature otherwise it will make your workflow extremely slow. Oh and I would also set the “VSync” settings to “Always off” also so you dont’ force your video card to obey your monitor’s refresh rate settings and thus limiting it’s full fps capabilities.
There you go, a full article on how to patch, install and setup drivers in Windows 2000/XP.
Something else to look at… make sure you read this article that the RivaTuner(&SoftQuadro) author has written himself. I found this to be extremely informative and I am sure many of you will find this very informative as well. http://www.nvworld.ru/docs/sqe.htmlhttp://www.nvworld.ru/docs/sqe.html
I hope you found this informative as it took me a good 30 minutes to write this.
If you need further clarification, then by all means, ask away.
Thank you very much…this worked!!!
I had to use the 21.85 drivers as they are the latest and greatest in Zip format. I could not find your recommended driver in zip format. Furthermore when I try to select Maya as a RTP (rivaa tuner preset) it sasy that it doesn’t know the 21.45 driver and cannot do this. Have you ever used the Maya RTP? If so what does it do? What driver where you using?
Thanks Again this really made my card rock!!!
Ohhh…I wasn’t able to use the antiprotection on this driver…I wonder if this will make things mess up in Maya…it was ok for a while…but then I tried to figure out what the force 16 bit buffer did…it made maya slow to a crawl…and when I turned it off again it still is slow!..interesting
Even though nvidia packs the drivers in an .exe file; if you have winzip installed; you can right click on the driver file and extract it to a folder on yer hard drive somewhere. Then you can apply your patch; then install the driver. Don’t install the quadro driver; just the geforce driver appropriate for your card. It will replace the openGL rendering driver with the quadro one for you.
That Ole Russell
Thanks efishta!!
Your explanation was a huge help. You saved me a lot of time and headaches.
Eroc
The 21.85 (or 21.45, whichever one you have) are not official drivers and I would recommend the latest official drivers to be used for 3D apps. Also, like he^ just mentioned, you can decompress the .exe files with WinZip or WinRar because that’s just a self executing archive. Third thing to do is to just look inside the “Database” folder where you decompressed RivaTuner and look at the driver database versions that are in there, and use only the ones there.
If you are going to install any drivers between 14.xx and 21.xx, then I definitely recommend that you check to make sure that there is a database available for RivaTuner for that specific version of the driver. This is extremely important because the antiprotection patch will only work correctly with the drivers that have a database included with RivaTuner.
If you don’t see a database for that version that you are using, then it means that RivaTuner will use a standart (non-certified) SoftQuadro script that has not been proven to work 100%.
Again make sure you try the 21.83 (which is the version I use and also the version that the RivaTuner author uses) as it does not cause some of the headaches that other versions cause. The 23.11 have had many users report problems. I would stick with the 21.83 if they don’t give u problems, but as always, experimenting is best.
All the drivers starting with 22.xx and above do not need to have the antiprotection patch applied, as NVIDIA did not implement the protection code in these driver versions (as far as the RT author can tell).
PS. As a side note, when you open RivaTuner next time, go to the credits tab and you will see my name in the beta-testing stage credits. hehe thanx Alex.
Ok I got everyhting setup exactly as you advised. Thank you…its’s working and quad buffered API is actually available in my display properties.
However I have one further question for you. When using Riva Tuner under the Power user tab I click on the little folder at the bottom with the plus sign. It then gives me the option to select an RTP (Riva Tuner Preset). There are a lot of them here, but being a Maya student that is the best option for mte to select. So I select it and I get this message-“Some preset values have not been configured in the current database. 16 of 16 values have been ignored.”
Now to me this means that Riva Tuner failed in loading the Maya preset. What does this preset do anyhow? Am I missing something? Will I lose any possible better performance without this preset?
Thanks Again
Glad you got it working first of all.
You should follow my advice and install one of the drivers that are more widely used, with 21.83 being one of them, 22.80 also being one and 23.10 or 23.11. (Just some off the top of my head.) This ensures that most if not all the presets are enabled because these are widely used drivers.
Make sure you upgrade to the latest version of RivaTuener just released on New Year’s Eve if I’m not mistaken. http://www.nvworld.ruhttp://www.nvworld.ru (That bit about the widely used driver versions is just an opinion and not a fact… just a possibility as to why you had that error message about the values being ignored)
This is what the “Maya, StudioTools.rtp” preset does.
  1. Enables VSync (this syncs the fps your video card is able to handle with the refresh rate of your monitor e.g. f your monitor is set at 85 Hz, the maximum fps (frames per second) you will get is 85 at any given time. This is not neccessary to enable…)
  2. Sets the Buffer Flipping mode to “Auto Select”
  3. Disables “Force 16-Bit Z-Buffer”
  4. Enables unified/back-depth buffer.
  5. Enables “Use page flipping in window mode when possible.”
  6. Enables Overlays (I definitely do not recommend this setting to be enables because it will dramatically slow down your workflow in Maya. I dont’ know for the other GeForce models, but my GeForce2 MX 400 dramatically slows down to a crawl when I enable them)
  7. Disables “Enable Stereo Support” option
  8. Disables Force Generic GPU
That the important ones that it sets… you can set them manually in RivaTuner if you get an error when you try to merge a preset.
In the new version of RivaTuner, all you have to do is just double click the .rtp files because RivaTuner registers the file extension with the program. Wowie (dont’ forget to run it for the first time, then it’ll register itself with the Explorer shell)
On the part where we are updating the driver and windows asks for the card type, you said to put in my card type. Can I put in the card type that I am trying to get from the RivaTuner or the card type that I actually have?
TIA
yes like the guide says, select the card that you own, not the card that you’re trying to “emulate”
and use up to 23.11 drivers, newer drivers aren’t supported.. as if those drivers aren’t new enough.
I was daring enough to enter the graphics card that I wanted not that I owned. Everything works fine…and a nice little feature is that it says I havea a quadro pro when i open display properties!
no comment… this is what the author said and he must have said it for a reason… whatever
if it works it works then sweet stuff
anyone know if ill have any issues doing this with a dual head geforce 2? I use the factory control panel for my split settings.. if i install detonator and the tuner will i still be able to split the desktop?
