Problem is my ISP cable provider has informed me that they only offer at this time Dynamic (DHCP) Addresses and not a Static Address as is required for Maya. I only have instructions on setting up a DHCP Address for XP. Can anyone help me on changing my IP settings so I have a Static Address? Aliaswavefront has requested I do these as a test but still has not been able to give any help on doing this. Or is there a way to edit my ethernet dat license file to recognise my workstation at home as a server?
SYSTEM:
PIII 900
30GB Maxtor HDD
Geforce 2 Quadro 64Mb Agp card
SOHOWARE Ethernet PCI 10/100 base adapter
Windows XP Professional
MAYA 4 Unlimited (ethernet dat license)
Rogers@Home ISP
worst comes to worst you can get a router (or a secondary computer) and set it up as a dhcp server.
ive got a linksys 4 port, its got built in firewall as well.
the router acts as a server, it gets the dynamic adress, while you and any other computers on your network get static ones, 10.1.1.01, 10.1.1.02, etc etc.
they run about 200 bucks at your local best buy or wherever.
theres probably an easier way, but it sounds like youve tried other things.
hope it helps,
cheers
As far as i know Alias is not responsible for our home networks Maya’s not qualified to run on XP either so why would you expect them to help?
I’ll help ya out.
start-control panel-Network connections icon
right click your lan connection
double click tcpip properties
(Make a note of how it’s all set now. you can change it back after)
click advanced and check the dns & wins tab
record this info too then remove it all.
click use the following ip address
add one of your own
e.g 192.168.0.1 (it’s a private address for local LAN’s)
click ok
best reboot even tho you shouldn’t have to. Thanks M$
btw all this from memory i think I got the steps in the right order.
yeah but if his isp is assigning him a dynamic adress, using 192.168.1.1 wont get him on the web.
and i wasnt suggesting aw would want anything to do with our home networks. that is just ONE solution, setting up a private network, manually assigning ips (i meant 192.168.1.1 instead of 10.1.1.1) BEHIND a server that is getting the dynamic IP. and that server can be a 200 dollar blue plastic box.
and i have run maya on XP, and i cant say i like it. not yet anyway, id wait for them to work the rest of the wrinkles out of that OS.
i think the point here is it’s a test not necessarily a complete solution. If this works it will tell him if it’s a network type problem or a maya one. agreed on your XP comment.
