I usually don't answer such questions as that's tech support's job, but I will just this once. Expect some inaccuracies somewhere as I'm not Softimage tech support
Since v2.0 uses SPM and not FlexLM, you can run both softwares at the same time with the two different dongles. It's working on my machine, it's advertised as doable, and so you should be able to run both as well.
The FlexLM dongle goes on the parallel port, the SPM dongle connects to your serial ports using the supplied 25->9 pin adapter. The SPM dongle will not work if installed on the parallel port.
By default, SPM looks for it's dongle on COM2, which defaults to serial port 2. If you edit the spm-config.ini file in your c:winntsystem32spm directory, you can change it to the other serial port. There's an environment variable towards the top of the file that provides this option.
To generate a license request, SPM must be running and looking at the proper port for the dongle (accessible thru lictools). Otherwise, you'll get a "Cannot find COM...." message. Also make sure you have the SPM_HOST environment variable defined. This tells SPM which machine acts as the SPM server.
After you've done all of the above, click the "generate license request" button in the lictools application then send that in to your reseller/tech support provider. They'll send back a license key in a file called "xxxxxx-SI0.keys", where xxxx is a cryptic code number. When this file comes back, open lictools and click the "install keys file" button then select the keys file in the popup file browser. I suggest placing the keys file in the spm directory before installing it (and keep a backup of the keys file elsewhere for safekeeping, such as on a readily accessible floppy).
Once the keys file is installed, you can run XSI. If not, rinse and repeat until all goes well. I've noticed that if you use custom 25->9 pin adapters instead of one provided in the box, you may have problems getting SPM to recognize the dongle.
Summary:
1) Install XSI software.
2) Connect 25->9 pin adapter to SPM dongle. then attach to serial port #2 of your machine.
3) Install SPM license server. Use machine's name when prompted for the SPM server name.
4) Start SPM server.
5) Generate license request file. Submit to your reseller/tech support provider.
6) Install returned license key using lictools.
7) Start XSI.
That's all I know of.
Matt
Matt Lind
Animator / Technical Director
Softimage|3D
Softimage|XSI
speye_21@hotmail.com
