Ive been a 3d Max user for 2 years and Ive finally gotten my hands on XSI. When I render an animation I am not able to save directly into an .avi or quicktime format…do I need a post-processing program to stitch all the individual frames into a playable format? Or can I save out to an .avi format in XSI?
Never, never render to an avi. If you are previewing use Flipbook.
Why:
If you render to an avi, if any setting is wrong you must render the entire set of frames over. Thus if you use the wrong codec, compression you can’t get the original frames back. If you render an umcompressed avi, you will probably drop frames playing it. Thus FlipBook is much better at this, since it buffers the data in memory much better than media player etc.
However, when you have rendered your frames and want to make an avi, here is a method:
Bring up a Softimage command prompt (You have an icon for this in your Softimage menu group).
Use the command “soft2avi”. To see the syntax, just type it and you will see the information for the command.
However here is a typical setup for 150 frames at a step of 1.:
