XSI skeletons
When I multi-select bones of a skeleton and rotate, only the first bone rotates!!!
And it jitters slightly so I thought the IK is overriding the FK. so I tried cuting the effector, parenting it to the last bone. And it didn’t do anything.
How do I get the correct (si3d) behavior?
Hi Laurent -
First of all, make sure you have the bones multi-selected, and not in branch mode. Secondly, make sure that when you are rotating, you are in “Add” mode in the control panel, and you should be fine. (I assume you are trying to do a curl-type deal on the chain)
BTW - cutting the effector or not makes no difference to the solving behaviour of the chain. It will solve in IK if the effector is controlled/animated regardless of it’s parent. BTW - if you want to solve in IK and also rotate bones and thus effect the IK solution (as in 3.x), select the first bone, go to the chain property page, and switch Solver Angles to “Use Joint Rotations”.
Hope this helps !
-gordon
Project Leader, Animation - SOFTIMAGE
Thanks Gordon,
With ADD it works. But why doesn’t it work in VIEW rot? I would like to see this behavior back since I mostly animate “2D” in 3D.
Also, how about making the “use joint rotation” the default behavior? Is there a reason why this isn’t the case?
Cheers,
