XSI to Max
Hello,
I wonder If I can convert from XSI to Max or Vice Versa...
It is possible to import the model with the animation and texturing done in XSI to Max...
Thanks in advance,
Abhi
Polytrans is your best bet for exporting an entire scene, but animation is hard because each program has a different animation system.
but why would you?
The best way is to render scenes seperately and in a post prodoction put it all together .
Hope that helps
Softimage has just released new exporters adn IMPORTERS for both Maya and MAX.
So you sould be able to go back and forth with the dotXSI file format. Granted some things wont be able to get back and forth, but for Geometry and stuff it should work fine.
Plus its free.
http://www.softimage.com/connect/xsi/
Vmpre
