Hi folks,
I was just wondering if anyone could tell me the major differences between XSI and 3D extreme?
Also does either XSI or 3D extreme have 3D and 2D paint effects or something similar,like Maya?
Thanx,
Wade
Hi Wade,
This will help:
http://www.xsibase.com/cgi-bin/netview/YaB…;num=1027541279
To answer your second question, there is no 2D/3D paint effect in both packages.
Hope this helps
Salutations - Cheers
Bernard Lebel
XSI is far more advanced than 3d Extreme, although extreme has the benefit of having had years of polishing. They are very, very different, although both share a similar mindset towards the way you approach creating artwork, and both have a speed of use and grace characteristic of softimage.
XSI adds a lot of things that were just not possible in 3d, such as the interactive renderview, shader networks, hair, cloth, a muuuuch more advanced particle system, some truly incredible subdivision surface modelling, and animation mixing integrated into every aspect of the application. You can do things like view a wireframe on top of which shadows (and ONLY shadows…or highlights, or a certain texture or whatever) are raytraced. You can create a complex animation curve (like imported motion-capture data), and then deform that curve with a simple one. You can create a particle cloud, and then animate it with IK and Forward kinematics at the same time.
XSI does not have a paint-effects-like tool, but it has and makes frequent use of painting surfaces interactively, using painting to select and deform geometry, and allows custom maps to be painted on any surface and used to code for any purpose. The thing about XSI painting is that it is much quicker and simpler to use than in maya, and can be used more extensively. But that’s where the functionality ends, you can’t use it like you do paint effects.
I should point out that it is vertex painting, with all the limitations, so don’t assume it’s a full-fledge 3D paint program. It’s meant to paint weight maps and the likes, not textures.
Right. Although I prefer XSI much more than SI3D, I must admit that working with SI3D was a real pleasure. Why? Because SI3D is solid a rock and of an awesome simplicity. I never had stability problems, messed up spdls, missing shaders, and the likes. No matter what I rendered, well, it rendered, plain and simple. With XSI there is still a lot of fiddling with the parameters to get the rendering right, and even then, so many things can really slow down or even crash your rendering. Plus, SI3D has many very useful functions, like Cleanup, Order, Bumpmap+, and the likes.
Still, I appreciate the strenghts of XSI and would prefer to see new features in it than having to go back to SI3D.
Cheers
Bernard
